Ir para o conteúdo principal
Infinite boot with black screen
Hi. iPhone6plus screen cracked and was left unused for months. I got new screen form ifixit, but after change phone does not “start". It power on and with a flashlight I can see a apple logo on the screen coming and going. So infinite loop with no backlight on the screen. Visual check says that cables and connectors are ok. Can a dead battery do this? Logic board?
Thank you.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
If you didn’t disconnect the battery while doing the screen repair, you probably shorted out the backlight circuit resulting in no backlight or a “blank” screen. You’ll need a board repair specialist to fix this issue as it results in a blown fuse or capacitor within the backlight circuit. It is not a repair you can DIY as it requires a lot of skill and thousands of dollars in tools.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
uula será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 12
Ao todo: 67
