Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
Battery won't charge when in MacBook Pro
Hello,
In case battery is not charging while MacBook Pro on but while its switch off then charging the battery. Sometimes the battery charges few seconds while it’s on.
Esta é uma boa pergunta?
Pontuação 0
3 comentários:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adicionar imagens a uma pergunta já existente
por
OK, lets now do a snapshot with the MagSafe charger plugged in.
Is the MagSafe LED Amber or Green, or just not lit at all?
por
Same status while plug in charger "Not Connected"
When I plug in its charge only 5 to 10 sec then not charge and not show charger plug in
por
Adicionar um comentário
1 resposta
If the MagSafe LED is not lit then the MagSafe connector on the cord and/or the system is dirty or damaged. Review this Apple T/N Apple Portables: Troubleshooting MagSafe adapters
Here’s an example of a damaged MagSafe connection
A common issue of damage is knockoff chargers!
Don't Replace Your MacBook Charger With a Cheap Knockoff
OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
Lacking safety features, cheap MacBook chargers create big sparks
FAKE Magsafe MacBook Chargers on eBay - Watch before buying a Mac Charger
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
bhadresh sonani será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 76
