hard drive raplace whit ssd
Can I upgrade my hard disk raplacing it whit an SSD only following the replace hard drive's guide on ifixit?
Esta é uma boa pergunta?
Sure, just make sure to use the jumper pins to take it down to 1.5 GHz if disk utilities won't see it.
Esta resposta foi útil?
The 2010 EFI and up should support SATA 3 & 6, there should be no reason to take the disk down to 1.5GBs with the supported operating systems for this model.
Hey AB he said IF disk utilities doesn't see it. Probably won't be a problem but that's the cure if there is one.
I've done this with an ocz agility 3, works fine at SATA III (6Gbs).
i have ssd samsung SM841n function perfect
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Duração total: 3,341
