Ir para o conteúdo principal
13" laptop part of Dell's E6000 series, released 2011. The device features a removable battery, optical drive, and is compatible with a variety of E-Port docking stations.
6 Perguntas Visualizar todos
Why don't my laptop turn on?
When it's turn on only the power light turn on and the processor gets heated within sec. The fan does not work.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Theophilus Effah  this “he processor gets heated within sec. The fan does not work. “ needs to get fixed first. It is possible that your laptop turns off because your CPU gets to hot or because it already has failed due to overheating. Replace the fan properly than re-evaluate. These instructions should help you to start your repair
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Theophilus Effah será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Duração total: 123
