Ir para o conteúdo principal
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Perguntas Visualizar todos
Can I upgrade SSD and keep Yosemite?
Hello,
I am shopping for a new SSD drive for my laptop (original capacity only 120G!). I would like to have 1 TB internal storage.
I cannot find an SSD drive that will allow me to continue to run Yosemite. Everything seems to tell me High Sierra is required to make the new drives work, but I do *not* want to upgrade beyond Yosemite. I just want more space!
Do I have any upgrade options for a simple swap?
(I’m afraid if I buy the OWC Aura SSD, for instance, it will banish my 32-bit apps and/or create other headaches I don’t want/can’t fix.)
Thank you in advance if anyone knows an answer to this!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You’ve got a bit of a mix of issues here!
Sadly to use the OWC drive you will need to upgrade your macOS to High Sierra as Apple altered the SSD drivers so 3rd party PCIe/NVMe drives can supported as of High Sierra. OWC had their own driver before that which is now obsolete.
So if you don’t want the OWC drive then your choice is getting custom Apple SSD. BeetsTech offers these drives:
These drives are running with the slower AHCI interface, this drive will also work but it will be running in PCIe 2.0 mode.
You then don’t need to upgrade your OS.
Now let’s clarify the 32bit issue. Catalina forces this not macOS High Sierra or Mojave! So you'‘ll need to worry about that at all running either of these macOS’s.
Here’s a good reference The Ultimate Guide to Apple’s Proprietary SSDs Take the time to read it. It should answer any other question you might have!
You’ll still need the OWC Envoy case to hold your current Blade SSD to migrate your stuff over.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Wow! I'm not sure where I got the misinformation that I would lose my non-upgradable apps by upgrading to High Sierra so this is definitely helpful. I will post a comment after I upgrade.
Thank you very much!
por
Adicionar a sua resposta
Robin será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 320
