Ir para o conteúdo principal
{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
276 Perguntas Visualizar todos
Touch ID Dont work after toucBar repair
Hi .I droped my mac .After 1 month and a lot of problems trying to use it without touchbar (restarted ) i read same information and manage to to the repair with a local technician .The problem is we manage to change touchbar but now touch id dont work .It said tha i have to delete some fingers and it wont show any. When i click down the marks it will load tha registration page but wont let insert any.The messege is try again .I tried software solutions. Is there any case this is on purpose for safety reason ?Thanks .Keep up the good work :)
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Did you replace the Power/TouchID button as well?
por
No .It worked before repair
por
Adicionar um comentário
2 respostas
Solução escolhida
If the power button was replaced during the repair then it won’t work. Biometric verification components such as TouchID and FaceID in apple products are tied to that specific device. Even if you purchased a brand new machine from apple and swapped the parts between the two, you would lose TouchID without the use of a special calibration tool that only apple and their service providers have. If the button was not replaced, it could’ve been damaged by the technician or it may not be connected properly.
Unfortunately apple does not like independent repair shops working on their devices because it effects their bottom line, but that is no way, any consumers problem. Apple has reached a net worth of 2 Trillion dollars, and they certainly didn’t do that by being honest or helpful to their consumers.
Esta resposta foi útil?
Pontuação 2
peris93 - You’ll need to bring your system into Apple sadly for them to fix this. You’ll also need to bring proof of purchase and a photo ID that matches the invoice.
Pontuação 2
2 comentários:
What is the point of doing that?
I know my passwords and I have access everywhere but not with the fingerprint.
por
@peris93 - If you want the TouchID to work you'll need Apple to fix it! Yes, you can still get into your system using the login/password.
Its just a matter of what you are willing to live with or in this case without!
por
Adicionar a sua resposta
peris93 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 660
