Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
iPhone stops charging after a week of not being used
So I have an Iphone5s that stops charging after not being used for a while. I at first thought it was the battery so I replaced the battery and it charged fine, then I put it away for a week and it stopped charging. help?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi madmikeizcool,
Looks like a common issue with trystar. A chip on the motherboard when faulty fails to charge dead/discharged batteries. Not worth fixing at this point in my opinion. Just get a new 5s or even 6s, would probably still cost you less
Esta resposta foi útil?
Pontuação 0
may be battery got drain so thats why your mobile is not showing any sign, in this case plugin charger for while ( 1 hour) even its not showing any sign,
second thing is as you said week ago you replaced battery it may be battery fault, contact the dealer or seller you bought from.
above information provided by ``krishna online store``
Pontuação 0
Adicionar a sua resposta
madmikeizcool será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 44
