Ir para o conteúdo principal
The 7" Amazon Fire ninth gen model was released on June 6, 2019 and featured 16 GB or 32 GB of storage space.
8 Perguntas Visualizar todos
Is there any way to install Qi charging
I have a car setup for using this tablet as a radio head unit but I can’t charge and use the CarPlay adapter at the same time is there a way to add Qi charging function to the fire 7 2019 so can be left fully in situe to allow use and charging in place
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
I know in the case of some older apple products before they added wireless charging there were cases available that would plug into the charging port. However I doubt such a product exists for your tablet and to add it would require a lot of work and microsoldering you’d be better off spending the money on a better tablet. So to answer your question, you most likely cannot add Qi charging to your tablet.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Michaela snow será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 367
