Ir para o conteúdo principal
O Nexus S é um smartphone desenvolvido em conjunto pelo Google e pela Samsung, sendo o primeiro smartphone a utilizar o sistema operacional Android 2.3 "Gingerbread".
no network
Nexus S I9020T does not work on mobile network state as "connected". It really works at home and office network on wireless acess points, but not at mobile network operator. This service is provided by the operator and works well on other cell phone, but not at this moment at Nexus S. It use to work well. Can i fix it by by my self or I have to deleaver it to Samsung costumer service? I do appreciate any help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
If you're using Sprint or Verizon (Or any other CDMA Network) and bought the phone used, then there is a chance that the device has a bad ESN number. It means that the phone is "blacklisted" and the network will not allow it to connect, because it has been reported as stolen, or it's original owner had canceled the network plan without paying the cancellation fee. Here is a thread that explains the full meaning of this. If the phone doesn't have a bad ESN, then do as rab777hp said, and check your carrier settings / obtain a new SIM card.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
Calling your carrier's customer support will probably work.
I'm guessing you either need a new SIM card, or have messed up APN settings.
Pontuação 1
Adicionar a sua resposta
Everardo Silva será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 999
