Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
Keyboard and touchpad not working
Hi all,
I have opened my MacBook to clean the fan as it was overheating. When I’ve re-assembled it, the keyboard and touchpad didn’t work.
The backlight didn’t work either. The keyboard and touchpad of the MacBook seem to be dead. That said the power button still works fine.
Can you help me determine what the issue might be? Maybe I forgot to plug in something but it doesn’t seem to be the case.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
I am fairly confident this is an issue with the trackpad flex cable. From your image I can see multiple pock marks and dents in the cable. They are known to go out easily on this model (they rub up against the bottom plate and degrade over time). When they go out both the trackpad and the keyboard become non-responsive. I would recommend replacing the cable and reinforcing with electrical tape. The trackpad cable is shown in Step 18 of this guide. You can purchase them online here.
Imagem de Replace the flex cable that connects the trackpad to the logic board compatible with the Early 2015 model A1502 MacBook Pro 13" Retina laptop. Part #821-00184.
Produto
MacBook Pro 13" Retina (Early 2015) Trackpad Cable
$9.99
Esta resposta foi útil?
Pontuação 1
3 comentários:
Thanks @zpl :) just placed an order for the cable. I will let you as soon as I replace it, if it has solved the issue
por
Replaced the part today and resolved the issue. Thanks
por
Glad to hear it!
por
Pergunta mais útil
Hello Sir,
Apple does offer a free keyboard + Trackpad replacement for eligible models that have not come in contact with any kind of liquid. If I were you I would bring it to an Apple store to see if your model is eligible for the replacement. As to why the problem happened in the first place, I have no clue, my only suggestion would be to check with Apple for a replacement.
Pontuação 1
3 comentários:
Might I note that the touchpad only comes free for models where the keyboard is fused to the frame, where apple just replaces the whole front panel
por
Thanks for the feedback. I'm going to replace the trackpad flex cable like @zpl suggested first. If that does not work, I will resort to this option
por
No problem! Good luck and have a nice day!
por
Adicionar a sua resposta
Lenard Camilleri será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 164
