Ir para o conteúdo principal
help my iPhone 6 plus isnt recieving signal
Hi guys got a problem with my iPhone 6 Plus I just brought
looks a lil bent and the some card holder which is fixed to the motherboard seems a touch bent.
The phone don’t read SIM cards but I popped my three network SIM card and I got WiFi calling which showed my imei when calling *#06#
Otherwise normally when WiFi calling isn’t active it won’t show any signal. Otherwise I go to setting it will show there’s a three SIM card inserted. I tried vodafone aswell same thing.
Any ideas plz help thanks in advance
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Sounds like you’ve got some sort of board issue with this one. Because the 6 and especially 6+ were notorious for bending easily, it led to board level issues such as touch IC disease where the touch IC chips would “pop” off the board like legos when you bend them. I’m wondering if your sim tray has come off or something.
Esta resposta foi útil?
Pontuação 0
1 comentário:
They SIM card tray is still firmly on the board and that the phone isn’t really bent that much I was thinking maybe it could be the baseband chip just below the SIM card holder I watched a few videos on YouTube with the same out come apparently also highly appearing in the 6 6 plus and 6s plus models. The Touch is all fully working without any fault.
por
Adicionar a sua resposta
Rakesh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 37
