Ir para o conteúdo principal
Third generation of the Fitbit Charge fitness tracker series.
19 Perguntas Visualizar todos
Will not turn on after charging
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
There’s not enough information here. Is this the first time you used the watch? Does it still have warranty? Was it swam with before this happened?
Esta resposta foi útil?
Pontuação 0
Hi I’ve got a similar issue, I left the Fitbit off for two months and when I went to charge it back up it come up with a Fitbit logo and 001. I’ve done a bit of research and I think this is a battery issue? Have you any ideas, any help would be appreciated. It is literally 6 weeks out of warranty and Fitbit just want to sell me a new one.
Pontuação 0
1 comentário:
Contact support if possible. The charge 3 has known issues. They sent me a free charge 3 after my screen went bad. If support tells you no, you could try and get a repair done, otherwise you may be out of luck. A charge 3 is immensely difficult to open without breaking the glass. (I tried with my old one, since they didn't require me to send it in, lol)
por
Adicionar a sua resposta
Done Here será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 295
