Ir para o conteúdo principal
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
20 Perguntas Visualizar todos
Replacement VVT solenoid won't fit.
2006 nissan altima SE 2.5L L-4. Pulled the code at AutoZone, “VVT in ‘advanced’ mode for longer than a set time.”. recommendation was to replace the VVT solenoid. Purchased a replacement solenoid at AutoZone. Removed the old solenoid, tried to install replacement but it won't seat fully. Upon inspection the distal ends of the two look different and the replacement will not fully seat, sticks out a couple of mms.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@msabo at this time the only thing to do is to return the one you purchased and get the proper one. Take the old one and compare it at the store to ensure you get the right one.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Matt Sabo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 190
