Ir para o conteúdo principal
Tudo que você precisa para reparar por conta própria o seu iPhone! A iFixit tem guias de reparo gratuitos e informações de desmontagem para cada um dos modelos iPhone, assim como as melhores peças de reposição e ferramentas da galáxia!
36478 Perguntas Visualizar todos
Face ID not working only when the phone is assembled
Hello everybody,
I’m a newbie DIY iphone repairer that learn everything from the internet. Recently I changed my iphone XR’s housing and screen because both my old housing and screen were damaged.
And I was faced with a mysterious problem. So before I clasped closed my phone’s housing and screen together I tested the Face ID and confirmed it was working flawlessly. But once I closed it the Face ID won’t work anymore (from Face ID to registering new Face ID).
A couple of days ago I managed to work Face ID with the phone closed only later to realize the screen wasn’t completed shut closed on its top right part.
When I used Face ID in that condition I noticed two red lights coming from the very left and very right from the turedepth system. But when I pushed and closed my screen completely as I was using Face ID, the red light from the very right of the system disappeared.
Looking at the truedepth camera system image above, I’m assuming the right red light came from dot projector, and therefore something is blocking it with the screen closed. Do you guys have any idea what could be wrong?
I screwed everything inside the phone. I hope I don’t have to tear apart the phone again to fix this since doing that takes a lot of time and energy. Seeing that Face ID works every time before the phone is sealed, I’m guessing there’s nothing wrong with all the sensors in truedepth camera system. If you got an idea that could help or you had a similar experience, please let me know below in comments!
Lots of Thanks,
Bo
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Hi, the cables are quite stubborn, if you bend it in the wrong way it'll stop working. If it works with the screen off I'd say you managed to squeeze a cable in between the screen and the body of your phone.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Hey, thanks for your comment. That sounds like a very likely possibility! I'll try to close the phone again considering that possibility and get back to you with the result. By the way, do you think I should tear the phone apart and put everything in the housing again for the cables of truethdepth system?
por
No need to tear the phone apart of your front camera works normally. The part you should be concerned with is the part which mounts onto your screen, around the camera holes. That's making the faceid work.
por
another possible issue could also be if you accidently tore the flex or if you damaged the face id itself when removing it from the phone and transferring it
Pontuação 0
1 comentário:
but if that was the case face id wouldn't work regardless of the phone being sealed or unsealed. Thanks for your comment though.
por
Adicionar a sua resposta
BKimc será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 136
