Ir para o conteúdo principal
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
White Screen at Startup
Everything worked fine before, but needed a new battery. Bought the new battery from Ifixit, replaced it, then booted it back up and now I get a white screen at startup. Tried to start in safe mode and still won’t get off of the white screen. Like I said it worked perfectly fine, before the battery swap. Any help would be great.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
A white screen is usually an issue with the hard drive. Check your hard drive cable to logic board connection.
Esta resposta foi útil?
Pontuação 1
2 comentários:
It does sound like my hard drive is having an issue. Keeps making like a whineding up sound
por
Looks like everything is connected
por
connect to external display if it still on white screen press command and r and press the power button the enter recovery mode
Pontuação 0
1 comentário:
Just tried and it won’t connect to the external display nor did it take the CMD, R, power button
por
Adicionar a sua resposta
Tyler Hockaday será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 103
