Ir para o conteúdo principal
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
Does not to boot up, tries
My MacBook won’t boot for hubby, I can’t try my log in because he did a forced shut off & it just comes back to his log in when turned back on. It just sits there looking like it’s booting up but 45 mins later it still in the same spot,
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Lets do this restart your system and press the D key so your system enters into diagnostic mode. Did it pop any errors?
Reference: Mac startup key combinations
por
Ok I ran the test a second time & was told no issues found. Code ADP 000
por
Adicionar um comentário
1 resposta
Solução escolhida
It was that age old problem I had with the old Macs….the PRam. I had it clear 3 times, it’s booting up fine, slow but fine.
Thank you so much for the referral to the codes.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
ladycerridwyn será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 67
