Ir para o conteúdo principal
My DSLR doesn't recognize my Flash
My Canon 750D / T6i doesnt recognize my external flash
I use Godox TT685C it worked on my Friend’s DSLR
I think The Problem is the Hot Shoe Maybe
*The little piece of metal that hides the Screws is missed.. but it doesn’t affect*
i tried Godox V1 and TT860 but also didn’t work
Imagem
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
I would start by cleaning the contacts with whatever alcohol you can find.
Update (10/04/2020)
Try:
- Update camera firmware
- Reset all settings (maybe some setting is making your flash not work)
If that doesn't help you will have to open your camera to take a look at the connections/wires, for what I see in the picture it has a lot of moisture/dirt that may have creeped inside.
https://youtu.be/hpnWB3Yzcac
Here is a disassembly guide
Esta resposta foi útil?
Pontuação 0
2 comentários:
Still doesnt work
por
Can Someone help me fixing this problem please ?
por
Adicionar a sua resposta
Ahmed Mohamed será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 909
