Ir para o conteúdo principal
Ice Maker not working.
My Whirlpool side by side does not make ice. I’m stumped. It used to work properly, but one day a couple of weeks ago, it just stopped making ice. Ice chamber is 5°. Filter is changed regularly (was changed last month). I pulled the ice cube unit. Inspection shows nothing. No frost build-up, no broken wires. Ice cube maker unit appears to be working fine as the bail goes up and down normally. I don’t think it is a water supply issue as I have water through the dispenser in the door, and the pressure is fine. How do I fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
This video may help you… repair-your-ice-maker …or not but you will be a bit better informed as to what the problem is at the very least.
Also this video may prove useful as well… Ice Maker Repair.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Randall Bowlsby será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 29
