Ir para o conteúdo principal
This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
78 Perguntas Visualizar todos
Does the stand from 24" Cinema Display fit on 27" model?
Will buy a 27” Cinema Display, but it has the VESA mount (doesn’t have stand), but I do have a stand from the 24” model, so, can anyone advise if I can install it on the 27” version?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
It will look quite odd! The stand will have the display at a lower point, likely scraping the bottom edge!
You really want to get either a VESA mount stand or replace the stand with the correct one.
There are some nice VESA mount stands that don’t need to be mounted to a desk if that was your concern.
Esta resposta foi útil?
Pontuação 1
6 comentários:
OK, thanks for your comment.
por
@lovecd - I did find the Apple P/N for the correct part 27" LED Cinema Display Leg/Stand, Apple P/N 922-9345
por
looks like it is hardly find that part available now.
por
@lovecd - True! Parts are getting hard for this older display. I would stick with the VESA mount stand Workstream by Monoprice - Easy Height-Adjustable Free Standing Single Monitor Desk Mount for Monitors Up To 27"
por
Yeah, I think I will go that route, thanks Dan!
por
Exibir mais 1 comentário
Adicionar a sua resposta
Tom será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 95
