Ir para o conteúdo principal
Announced in August 2017, the Galaxy Note8 is the successor to the recalled Galaxy Note7. The Note8 was made available to the public for purchase in September of 2017.
Poor performance after battery replacement
I replaced my battery with a new part from a reputable UK seller, and the device continued to operate fine for two weeks, however the battery calibration appeared to fail a couple of days ago and now the device is running at approximately 1% of the expected performance when on battery (5+ minutes to boot as opposed to a few seconds), and yet when connected to the charger it runs fine again. Do I have a faulty battery?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Alistair,
Good afternoon! I have seen this issue many times with replacement batteries. More than likely you did get a defective battery. Check with the seller to see what their warranty period is and try to get a replacement. I just had a note 8 do this same thing a few weeks ago. Hope this helps!
Roy
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thanks Roy, I was hoping this wasn’t the solution but I’m inclined to agree with you - Back through the layers of adhesive again I guess!
por
Adicionar a sua resposta
Alistair McShee será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 18
Ao todo: 175
