Ir para o conteúdo principal
The Xbox One X (Model 1787) is Microsoft's high-powered game console, succeeding the Xbox One S. The Xbox One X was released on November 7th, 2017.
159 Perguntas Visualizar todos
Is it posible to replace the ethernet port?
Can the port be replaced?? My son nocked over my Xbox One X and a small piece of the plastic that holds the Ethernet cable in is broken and will need to be replaced is this possible?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Yes, the port can be replaced. But I am not sure if the limited warranty would cover it but I do recommend you contact support to get it fixed seeing as ethernet is the most reliable way to connect to the internet.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Senn2729 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 6
Últimos 30 dias: 10
Duração total: 402
