Ir para o conteúdo principal
This product is a 27-inch LED display with a resolution of 2650x1440 pixels released by Apple on July 27, 2010. It has the model number A1316.
Vertical line on the screen (1-thin red)
The line is thin for the most part. Does not bother me but it is a little annoying knowing its there. Can I fix this or do I need to take it to Apple? See picture attached.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
its the lcd . you need to change your lcd/screen
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thank you for the comment. The LCD/Screen? Sounds like it should trashed? Sounds expensive. Can you elaborate?
por
Hi it's not really expensive and it's not too hard to change, you just need the right tools. But u need to change the LCD, not just the screen.
por
Adicionar a sua resposta
Jose A. Colon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 14
Ao todo: 158
