Wshirlpool Washer stopping during agitation cycle
Washer stops during wash/agitation cycle.
Wash light remains lit (green), door light (red) is off and door is unlocked.
Lifting the lid does not turn off the wash light.
Pressing the start button results in the cycle beginning again.
I have gone through various steps - resetting by unplugging the cord being first.
I entered the diagnostic mode.
I ran the check for error codes. There were no error codes.
I manually checked each function - cold and hot water, low and high spin, low and high agitation, and drain pump. All turned off and on and worked properly.
I then ran the machine’s self-test function. It ran though that completely with no issue.
I tried the ‘Drain/Spin’ function on the selector dial, and it seemed to work. I haven’t tried any of the other non-wash functions (soak, spin).
I have tried the Regular, Light, and Quick Wash functions all with the same result as above.
Amy ideas? Thanks in advance!
The washer is a Whirlpool WTW4950XW3
Esta é uma boa pergunta?
You mentioned the door is unlocked. Is it supposed to be locked during the cycle?
por Felicia Johnson
Yes. The door locks once you start a cycle, and remains locked until the cycle is complete. At that point, the 'Done' light illuminates green, and the locked red light is off. What's happening with my machine is the washer is acting like it's through with the cycle - the door is unlocked and the red light is off, but the 'Wash' light is lit green, not the Done light.
por Jeffrey Dreves
