Ir para o conteúdo principal
Released September 21, 2018. Models A1920, A2097, A2098, A2100. Available as GSM or CDMA / eSIM or nano-SIM / 64, 256, or 512 GB / Silver, Gold, or Space Gray. (Pronounced "iPhone 10 S.")
Battery verification message after replacement
I know this is an obvious and well-known problem, still I’d like to listen to some input from this community.
I just replaced a client’s iPhone XS battery without doing prior research. If I had known what kind of childish games Apple was playing, I wouldn’t have accepted the job. Client is now complaining about the battery error message that keeps popping up every 10 minutes. He doesn’t care much about the “service” label in battery health. The pop-up is extremely annoying though.
Is the only way to fix this issue to solder parts from the original battery onto the replacement one? If so, I’ll remount his original battery.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
There is a way to fix this issue but you will need an activation board and experience in microsoldering. Rewa have a video on the procedure.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Sam será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 4
Ao todo: 151
