Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
794 Perguntas Visualizar todos
Re-enabling the startup chime.
Yes - this is another of my rather picky issues.
I have a 2010 13” Unibody I’ve been using for quite a while, and something that’s been bothering me is its lack of a startup chime. I believe this is something that can be done using the terminal but everything I’ve found on the web is for the newer Macs that don’t have the chime enabled by default (StartupMute=%00) which obviously doesn’t work. I’ve also tried the mute trick (had no expectations and got nothing).
I had one time where I did an NVRAM reset on an iMac and the next thing I know the chime blasted at a rather high volume. Obviously I tried it. It didn’t work.
Does anyone know how I can get the chime back? Thanks.
Edit: Apparently StartupMute=%00 also works on older Macs but it still doesn’t work on mine.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Here’s a good YouTube Vid on enabling/disabling: How to Turn on the Mac Startup Sound - Krazy Ken's Tech Talk
Here’s some back history: Macintosh Startup Sound History - Bring Back the Bong! (RIP 1984-2016)
Enjoy!
Esta resposta foi útil?
Pontuação 0
2 comentários:
That's the StartupMute=%00 solution. I already mentioned how it didn't work.
por
It works on my MacBook Pro's! What is your OS-X/macOS ? Are you using something old?
por
Adicionar a sua resposta
amatsuda será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 41
