Ir para o conteúdo principal
The Powerbook 5300 is a 10.4 inch Apple laptop running on Macintosh System 7. It was the first to use the Power PC architecture.
1 Perguntas Visualizar todos
Repairing power connection , intrenal
When power cord is connected,no power ,green light does not go on.
Is there an easy fix to this or must I re solder ,on interior of book.
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
IIRC that model had known problems with the battery and the power connector. Check the cord with a multimeter to be sure its providing voltage to the computer. If it is you will need to check out and quite likely need to repair or replace the power connector. I am including a link to the guide that comes closest to assisting you with disassembly. Good luck.
Apple Powerbook 5300 Hard Drive Replacement
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Douglas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 784
