Ir para o conteúdo principal
The Nikon D80 is a digital, 10.2 megapixel, single-lens camera that was released to the public in 2005. It is meant for digital photo-taking and filming.
28 Perguntas Visualizar todos
What is loose in my lens?
I don't know if there is a loose piece in my lens or in the camera body. When I tilt the camera, something loose obstructs one of the corners in the photograph.
What is it and can I fix it myself? It also seems to affect the color sensing as the photograph is faded and bright.
Esta é uma boa pergunta?
Pontuação 2
1 comentário
What happens if you change lens? Sounds like the iris.
por
Adicionar um comentário
3 respostas
Solução escolhida
To see where the problem is, select various f stops from 2.8- 32 (or whatever lens has) and watch the way the iris responds. Open to largest aperture and try rotating again to see whether any blades are falling out of position..
having tried this on my SLR camera you may need to leave the lens on to check the iris, to do that you may have to open the back of the camera, select B for exposure and whilst the shutter is down turn the aperture ring to watch the iris. Depends where your aperture ring is.
turn camera on, flash off, lens off. Select longest possible exposure time,either B or 1. Depress shutter and keep held down, look in where lens is meant to be,rotate camera to see what if anything is obstructing CCD. If yes then get back to us. I believe you should be able to fix most camera problems yourself, I'm not too familiar with your camera so this general advice. Your f-stops are prob on camera body but...
Esta resposta foi útil?
Pontuação 4
Had a similar issue recently and it turned out it was the UV protection filter. Something similar to an O-ring was just out of place making the glass tap against the metal. Got my Gerber and popped it back into place with the knife.
Pontuação 0
I think you have to check the lens of whether have a problem, or to relevant repair shops for advice and repair. Maybe you only change new camera gadgets. SPAM REMOVED
Pontuação 0
Adicionar a sua resposta
k solis será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 16
Duração total: 5,611
