Ir para o conteúdo principal
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
281 Perguntas Visualizar todos
Will a 2016/2017 used battery work on my 2015 MacBook?
I bought my Macbook at mid-2015, so naturally It’s battery is almost dead and I got the “Service battery” warning already.
I found someone selling an original battery, still glued to the bottom case, but I don’t know the year of the Macbook where that battery came from. Is it important?
I don’t know if there are incompatibilities between batteries from different years.
Update (09/21/2020)
Thanks for the answers!
I finally changed my battery and everything is working perfect so far.
The backplate was not a 2015, and the battery was model A1705.
The only problem I had was that my motherboard wouldn’t fit the new bottom case, so I had to cut a piece of the frame that holds the motherboard to make it fit.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
MacBook batteries as far as I know are all intercompatible, 2015-2017.
Esta resposta foi útil?
Pontuação 1
Pergunta mais útil
The A1527 Battery for Apple MacBook 12 Inch Retina will work in the A1534 2015 2016 Mid 2017
Pontuação 2
2 comentários:
iFixit lists a higher Wh for the 2016-2017. Will that fit the 2015?
por
Wondering the same as Paul. A1527 (2015 battery) has 7.55V and A1705 (2016 battery) has 7.56V. Doesn't seem like a big difference, but would it make an actual difference in the MacBooks life? Is it risky? (I want to use the A1527 in a 2016 laptop that came with a A1705).
por
Adicionar a sua resposta
Agustin Campeny será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 15
Duração total: 603
