Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
iPhone 7 has weird charging animation
Hi.
I have noticed with my iPhone 7 that it I turn it off and then plug it into the charge instead of turning back on like all apple devices it shows this battery icon (see picture) which I have never seen on any of my apple products. If I then hold the power button it turns on. I also noticed that in settings Wifi is called “WLAN” and has some strange settings I have not seen on my other iPhone 7. Henceforth whenever I open a app it asks me if I want to use only WLAN or WLAN AND WIFI with the app. I checked all the serial numbers and it is all legit and everything else is identical to my other iPhone 7 so it is a real iPhone.
any ideas?
cheers
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
What OS is the device running?
por
Adicionar um comentário
1 resposta
Hi, Quinn, I am an electronic engineer and have a degree in computer science. China models have WLAN instead of WiFi, therefore i believe this is a china model and hence the weird animations, what is the model number (For example - A1668) and then i can tell you for sure
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Quinn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 72
