Ir para o conteúdo principal
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 Perguntas Visualizar todos
iMac Shuts Off When Seating Display Back into Frame
The power supply went bad in the Imac so I replaced it. The computer will boot with no problem now until I set the display back into its proper location. Even having it tilted out 2 inches it will work until I set it all the way back and then it shuts off. When everything is connected to the display all 4 led’s light up on the logic board and the screen works. Even with the screen completely disconnected from the motherboard it will shut off as I place it back into the frame!? I can disconnect the display completely and run the computer off of an external monitor. I’ve checked for loose cables and cannot reproduce this until I put the screen back in. Very strange situation! Any help is greatly appreciated!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The display might be pinching some cables, or unplugging them slightly. It also could be shorting out in bare metal somewhere.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Dan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 23
