Ir para o conteúdo principal
The seventh iteration of Apple's iPod Touch, released May 2019. This model comes with up to 256 GB of storage and an A10 processor. Model number A2178.
Possible LED Issue Due To Drop
Hello! I have a 7th generation iPod Touch that dropped (while in a case) from about a two and half foot tall counter. The screen immediately started to fade white outwards and then right after started to fade black in towards the middle of the screen. It even has a few dark dots. I wasn’t able to see if it hit a specific corner at the time since it happened so fast but is this problem something I can fix?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Are you able to see the unit when connected to your computer via iTunes? If you are then it sounds like you damaged the display assembly and will need to replace it. Here’s the guide iPod Touch 7th Generation Display Assembly Replacement and here’s one source of the screen iPod Touch 5th / 6th / 7th Gen LCD and Touch Screen Replacement
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kaashi será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 5
Ao todo: 168
