Ir para o conteúdo principal
Released October 26, 2018. Models A1984, A2105, A2106, A2108. Available as GSM or CDMA / eSIM, nano-SIM or dual-SIM / 64, 128, or 256 GB / Black, White, Blue, Yellow, Coral, or Red. (Pronounced "iPhone 10 R.")
468 Perguntas Visualizar todos
Can the front facing microphone, for Siri, be replaced.
Siri stopped working and I tried turning Siri off and back on. I wasn’t able to go through the “hey Siri” setup. It had images of noise while nothing is said. I tried a front self video and the sound is scratchy. I have also tried a full restore and reload…. after tapping on the microphone at front camera, it is working now but I’m sure it will quit again.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi yes, the microphone is replaceable however I believe you need to desolder and solder a new one on. If you want to replace the whole front assembly then Face ID will no longer function. If I remember correctly only swapping out the microphone won’t affect Face ID.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Barry Richardson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 74
