Ir para o conteúdo principal
The April 2014 update of the 11" MacBook Air packs refreshed dual-core i5 and i7 Haswell processors and slightly increased battery performance.
98 Perguntas Visualizar todos
My MacBook Air won’t power on
All the sudden my MacBook Air stopped powering on. I tried holding the power, the option+command+P+R and/or Power. Nothing, no noise at all. My charger seems to be working and will go from orange to green after a few hours of charging. When doing the SMC reset, the MagSafe does change colors for a few secs. I opened the back and disconnected the battery for 10mins, put it back and it still won’t start. I then tried detaching the touch pad as well and still nothing. In addition, while the battery was detached I attached the charger, but it still wouldn’t start, nor would the fan start. Do you think it’s the logic board? Any suggestions welcomed!
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
Hi @robnyc22
You said you tried holding the power, the option+command+P+R and/or Power. This happened to my grandmas MacBook Pro and what I did was I held option+command+R and then held the power. It took about 10 seconds but I got it turned on. Let know what happens.
Brayden
por
Adicionar um comentário
2 respostas
This may require some additional diagnostic steps. It’s possible you have a bad battery. These batteries are relatively easy to remove. If you have a friend with the same model machine you can ask to try their battery in your system. See this guide for battery replacement steps.
It might also be a failed IO board (the component which houses the MagSafe 2 port, USB-A port, and headphone jack). You can see the steps for replacement here. Before trying that replacement it might make sense to test the voltage passing through the MagSafe 2 port. You can do this by using a multimeter to read the voltage. Set the multimeter to read DC voltage. Then connect one terminal to the pin circled in red. Connect the other terminal to the pin circled in yellow. Be careful when doing this and keep your hands steady (if you connect the wrong pins you might have a spark). Record the reading on the multimeter. It should be around 14.5 V for a MacBook Air (it doesn’t matter if it’s positive or negative, that depends on the pin configuration). If it’s less than this the IO board may need to be replaced. If it’s more than this the logic board may have a short which is causing it to draw too much power.
Imagem de MacBook Air 11" Early 2014 Battery
Guia
MacBook Air 11" Early 2014 Battery Replacement
Nível de dificuldade:
Moderada
15 minutes
Imagem de MacBook Air 11" Early 2014 I/O Board
Guia
MacBook Air 11" Early 2014 I/O Board Replacement
Moderada
1 hour
Esta resposta foi útil?
Pontuação 0
Hello Robert!
Inside your computer is a small button battery which is used for the CMOS, or BIOS. If that battery dies it will cause all sorts of problems like not starting up, starting up then shutting off, etc. Usually replacing that battery will take care of that problem.
If that doesn't work your main battery could be going bad. Bad batteries cause all kinds of problems, it doesn't matter if its in a car, a phone, or a computer. Check both those batteries out and post back with an update.
Best of luck.
Eddie
Pontuação 0
Adicionar a sua resposta
Robert será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 254
