I know its still too soon...
I would like to know what kind of adhesive they used on the Note 20 Ultra. I have Flintstone fingers and so now I have a repair to do.
Esta é uma boa pergunta?
Well that device is quite new so replacement parts may be unavailable for a little bit. With that being said I tried finding pre-cut adhesive but can’t seem to find it. If we repair shops can’t find precut adhesive, we’ll use this: Tesa 61395 Tape
It’s made of the same tape as the pre-cut stuff we use but it’s not like factory. You can use some heat and some pressure to kind of cure the adhesive to make a good bond.
just keep in mind that since you damaged your device, and you’ll be opening it up, it will lose the liquid resistance.
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 298
