Ir para o conteúdo principal
Baseband CPU shortened (U_BB_RF)
Hi,
I was repairing a water damaged iphone 6 when i removed the short on PP_VCC_MAIN, i restored it because of the passcode on it. After restoring i noticed that i couldn’t activate the phone, so i discovered a short on VREG_SMPS1_0v90 and when i removed the baseband cpu, the short was gone. How can i repair it or bypass activation ? thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
There is not much you can do if the short is in the baseband IC itself. What you can try is to inject voltage into that line or pad on the IC. This sometimes burns the short out, at this stage you have nothing to lose.
Esta resposta foi útil?
Pontuação 3
6 comentários:
Ok. So how much voltage i should inject in ? also it's impossible to buy a new one ? Thanks
por
@anthony10006 No the baseband CPU cannot be replaced as it is married to the CPU. You will need to get the short out to have a working phone.
I don’t know how much voltage you should inject. Usually if a 4V circuit has a short and you inject 4V into it only 1 or 2 volts might be going into the shorted component. You should start with 1V and increase as needed. This method doesn’t have a good success rate but as I said you have nothing to lose.
por
Okay I’m gonna test this thanks
por
well i injected more than 16 v and the short is still there even after reballing :/
por
@anthony10006 As I said, this method doesn’t have a good success rate. Unfortunately there is nothing else you can do .
por
Exibir mais 1 comentário
Adicionar a sua resposta
Correia será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 335
