Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
My IFixit replacement battery is not recognized, even after SMC reset
I recently installed an iFixit battery in my mid2009 MacBookPro 13” unibody. The battery worked fine for a while, but now the laptop cannot draw from battery power at all.
I tried resetting SMC and PVRAM, but the laptop still shuts down hard when the power cable is pulled. System report for Power shows:
Charge info:
  • charge remaining (mAh): 5000
  • fully charged: yes
  • charging: no
  • full charge capacity: 5000
  • health info:
  • cycle count: 27
  • condition: replace now
  • batt installed: yes
  • amperage: 0
  • voltage: 7000
How do I get this battery working again?
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see Adicionar imagens a uma pergunta já existente
por
Adicionar um comentário
1 resposta
The battery its self appears to be OK, At this point I’m thinking your systems SMC logic (power control) has a problem. Most of the time when I see this the MagSafe charger being used is a knockoff which damages things.
Don't Replace Your MacBook Charger With a Cheap Knockoff
OEM MagSafe Chargers vs Cheap Imposters: Teardown for Truth
Lacking safety features, cheap MacBook chargers create big sparks
FAKE Magsafe MacBook Chargers on eBay - Watch before buying a Mac Charger
Here’s the needed REAL MagSafe charger Apple 60W MagSafe Power Adapter (for MacBook and 13-inch MacBook Pro)
Don’t buy the ones listed on Amazon or eBay they are not real chargers!
Sadly you’ll need to find someone with the needed skills to fix your logic board.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Raymond Rozman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 68
