Ir para o conteúdo principal
Repair information and guides for the 2015 Retina MacBook Air. Model A1534
20 Perguntas Visualizar todos
Replaced battery but won’t turn on
Hey,
I have just replaced a battery for a customer but the MacBook will not power on.
i have followed all steps carefully and check them again but no success.
i placed the MacBook on a low voltage charge as you suggested, I reopened the MacBook and checked all ribbons and connections and everything is how it should be. The little light on the logic board for the battery power is on as well.
is there something I am missing?
Thank you
Esta é uma boa pergunta?
Pontuação 2
1 comentário:
did you manage to fix this? im having the same issue, after battery replacement, macbook went dead. i can see the tiny LED lit up on the motherboard, but no chime, power, i can feel ir warm when charger is plugged
por
Adicionar um comentário
1 resposta
From the info you have provided, it is highly likely you have a faulty battery. Here is a link to the Ifixit replacement battery: MacBook 12" Retina (Early 2015) Battery
Retina MacBook 2015 Battery Replacement
Imagem de Replacement 4800 mAh battery for MacBook 12" Retina (Early 2015).
Produto
$109.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mark walker será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 78
