It will not get channels I have cable from wall
My TV has only one channel i tryed everything
Esta é uma boa pergunta?
Hi Kiana Flores
It would be good to share where and which country you are located, so
Just to check when you do a full channel scan, it only show one channel? how about other tv? had you test the outlet with another tv?
https://www.manualslib.com/manual/169081...
In rare case if the tuner could be faulty and the hdmi ports are working well, you can consider getting a set top box to receive channel and connect to hdmi port
Esta resposta foi útil?
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 9
Duração total: 67
