Ir para o conteúdo principal
Announced in March 2015, and released April 10, 2015, the Galaxy S6 is the next flagship in the Galaxy line. The curved screen version is known as the Galaxy S6 Edge.
486 Perguntas Visualizar todos
Samsung S6 won’t turn on only showing (white led)
I’ve tried most key combos. I’m going to take this explanation from DroidGuy because it matches my exact problem. “I have a Samsung Galaxy S6. I had it hooked up to the charger all night, woke up the next morning, saw that the battery icon was full and green. When I went to turn it on, the whole screen went black and I have not been able to get it running again since. I tried all the troubleshooting there is, still nothing. The only thing that happened is a solid white LED light.“ The phone has a lot of sentimental value to me and it’s not an option to take to the store help?
Esta é uma boa pergunta?
Pontuação 1
2 comentários
you fix this? i have the same problem
por
I’ve just found my old Galaxy again which has this exact problem. Still no way to fix this?
por
Adicionar um comentário
5 respostas
Pergunta mais útil
I have this problem on the s6 edge+. phone boots up and after a minute it freezes and then shuts down or restarts with the white led on. Cannot use it for more than a minute unless i constantly engage the digitiser(by drawing a 0 on the screen or in a pencil erasing motion). So i’m guessing this issue could be a display shorting or something related to the display connector.
Esta resposta foi útil?
Pontuação 1
try using another charger or if that doesnt work do a master reset usually when u gimet the white light its a sign battery is dead
Pontuação 0
1 comentário:
Hi... I have the same issue ... but in desperation I banged it a little then it worked for few hours and now it’s back to the white solid light ... I tried the same trick again and it is just stuck at the Samsung boot up screen. Frustrated ... wonder if someone can help please as I also have a lot of memories saved up in that phone and I don’t want to completely erase it until I have the memories backed up. Any help please ?
por
After you turn on the phone, you don't need to do anything. After a period of time, the device may be able to boot normally. This is one method I have tried.
Pontuação 0
It happened to me now and it happened previously. Just wait for the charging to end and then it will open
Pontuação 0
1 comentário:
sorry what do you mean, charge it fully then it will turn on? thanks
por
This problem is related to a hardware issue.
Could range anything from NAND/UFS failure or issues with the RAM or anything.
Samsung hasn't documented anything on this.
I'm still working out what it could mean.
Pontuação 0
Adicionar a sua resposta
Fix S6 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 45
Últimos 30 dias: 213
Duração total: 7,930
