Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
678 Perguntas Visualizar todos
No home button function but Touch ID works
Hello everyone. I have an iPhone 8 Plus that the Touch ID works but the home button function doesn’t. I assumed it was a damaged flex or component on the flex so I tried two other known working aftermarket buttons. Neither of those worked either but they work on any other phone. I also tried another display with all three buttons and it’s the exact same every time. Can someone please give some input on this? Thanks everyone
Esta é uma boa pergunta?
Pontuação 0
4 comentários:
is the connector on the board for the Touch ID cable ok, Any bent pins?
por
I looked at it with a magnifying glass and I don’t see anything bent. She’s bringing her phone back soon for a new screen since she cracked her new one within three days so I’ll check it again. I haven’t restored it or tried the dfu mode yet but I’m doubting that would help. I might still try incase it is a software related bug. It wasn’t working when she brought the phone in the first time and it had never been repaired before so I don’t think it would be the pins but it’s definitely worth a second look.
Thanks for the reply
por
So it wont take you home but dose register touch id. its not a tactic engine problem right.
por
No. The Taptic Engine works for everything else. I don’t feel the simulated click but the home button doesn’t function at all except for the Touch ID
por
Adicionar um comentário
1 resposta
So you have tried those chinese “fake” home buttons? And they work with other phones, but not with this one?
Have you tried other LCD?
I had the same issue and it was U10 (turtle IC). I replaced that IC on home button and now it’s working.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Yes those buttons do work lol just not on this phone and I did try another lcd. Would it be possible for me to mail this home button to u and have u try that with this one?? I know it would be best to have the phone to test it on but that probably won’t be possible. You know people are attached to them
por
If those chinese buttons does not work, then it's probably a motherboard issue.
por
Adicionar a sua resposta
Neil Borne será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 51
