Battery not charging or holding a charge.
this iphone will not hold a charge i can plug it up to the wall and it works perfectly but as soon as i unplug it goes off.
Esta é uma boa pergunta?
Definitely a battery problem! Change the battery, or better yet, see if it is covered by a warranty and let the company you bought it from replace the whole phone.
Esta resposta foi útil?
Just replaced battery from here last night, worked fine. Put it on charger last night, as I normally do and it was dead when I woke up. It has the battery picture on the screen, but says it is charging, but won't turn on at all. Did I mess something up or is it a battery problem once again?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 2,951
2 comentários
Is there water damage? the connector for the battery might be corroded and need to be reflowed.
por iRepairMan
New battery?? Just a guess...
por iRepairMan
