Ir para o conteúdo principal
iPhone de quarta geração lançado em 2010. O reparo é simples, mas o vidro frontal e o LCD devem ser substituídos juntos, como uma unidade. GSM / 8, 16 ou 32 GB de capacidade / Modelo A1332 / Preto e Branco.
2396 Perguntas Visualizar todos
Battery Connector Broke off?
I pulled the battery off wrong and pulled the connector off the board. I soldered it back on and its working now because when i hook a battery up it will turn on without being plugged in. Im just wondering about the connections on the connector i was able to solder the four contact points in the rear but the two on the front that are underneath i dont know how to get at to solder them but do they matter as long as the four in the back are soldered?
Esta é uma boa pergunta?
Pontuação -1
3 comentários
does anyone know
por
come on someone help me out
por
jared, have you checked on your PCB to see where the two other points connect? Any traces coming of them? If your battery works, charges etc, it is possible that those two are to hold the connector onto the board.
por
Adicionar um comentário
2 respostas
Solução escolhida
I guess im better than you at this stuff then because i replaced mine and now its working 100% again :)
Esta resposta foi útil?
Pontuação 0
1 comentário:
+ excellent job and congratulations on getting it accomplished.
por
There's no way to get it fixed bud, you'll have to get a new one to replace it right away.. Wish you luck
Pontuação 0
3 comentários:
as you can see, there is always a way. Have some faith....;-)
por
Quoting "Replace it right away" If you didnt get it, means replace the batery, i guess its what you did.
por
actually no i replaced the battery connector on the board not the battery what i did actually requires skill
por
Adicionar a sua resposta
Jared será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 831
