Ir para o conteúdo principal
Repair guides for the MacBook.
3786 Perguntas Visualizar todos
Is there no inverter cable?
I have this Early 2009 Macook 2.0Ghz Core 2 Duo. I bought it with this problem where the backlight goes off at about 45 degrees and comes back on somewhere at the 120degree angle. I tried to look for parts but I cant find any inverter cables. I know these sometimes break internally and it has happened with one of my older ones, which I did replaced. I cant find the same part for this laptop when I researched it on Ifixit. Does this not have the same cable that the older ones had?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Yes there is an inverter cable for the early 2009 MacBook. It takes the same one that the MacBooks late 2007 Santa Rosa - early 2008 Penryn use ( 3 wall connector on the board). Ifixit does not have any in stock at the moment. Here is a link verifying that the early 2009 MacBook takes the same cable I mentioned. Here is a google shopping search for the part.
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
Zahan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 786
