Ir para o conteúdo principal
Tudo que você precisa para reparar por conta própria o seu iPhone! A iFixit tem guias de reparo gratuitos e informações de desmontagem para cada um dos modelos iPhone, assim como as melhores peças de reposição e ferramentas da galáxia!
36480 Perguntas Visualizar todos
Cheap but quality no clean flux for iPhone soldering
Hi guys looking to start up microsoldering I’ve watched videos etc brought myself a station etc.
Just struggling to find what flux to use. I know no clean is best but don’t know which one to purchase?
any help will be great thanks from previous experience .
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
I use “CHIPQUICK SMD291” Have been using it for years. Everyone has their favourite flux so you should try a couple of brands. I know a lot of people use “Amtech 559” Different fluxes burn away in different time spans so it comes down to soldering technique and how long you want the flux bubbling under the IC before it burns away.
Esta resposta foi útil?
Pontuação 1
1 comentário:
@imicrosoldering would something like this eBay item link be suitable do you think?
https://www.ebay.co.uk/itm/252930143576
por
Hi
Iv got a decent amount of soldering experience and from what I know is that most flux do the same thing you just need to get it from a reputable source because there are lots of knock offs
But from experience I would recommend something from amtech or chip quick (most people use these)
But don’t feel like it had to be one or the other because they all do a very similar job
Hopefully this answers your question
Pontuação 1
I also use Chipquick SMD291NL flux as shown in the picture on the following webpage:
I purchase it on Digikey.
Pontuação 0
1 comentário:
soldering iron you do want to slow down in adding your links. They all go the the same site. You have been on here for 12 years and by now you should recognize that this is getting pretty spammy.
por
Adicionar a sua resposta
Rakesh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 3
Últimos 30 dias: 12
Duração total: 360
