Ir para o conteúdo principal
Apple's March 2019 refresh of its iPad Air tablet, sporting an A12 Bionic processor and a 10.5" screen.
Screen White Pressure Point
Ive been seeing this white spot on my screen, and the reps at Best Buy said it was a pressure point on the screen. I tried using a small vacuum pump to try and pull the screen back up from that spot, but it hasn’t fixed it.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Best Buy Geek Squad really doesn’t know much about repair other than selling a solution. That white spot could be a couple things like a pressure point if the frame was bent or the battery swelling, although that doesn’t seem likely as that tablet came out just last year. It could also be a defective LCD.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Any thoughts on how I could possibly fix it? Everything else works fine. Just that the spot itself is right there in my line of sight and what I’ve tried so far doesn’t work
por
@ibsinrg you'll have to take it apart to find out what's wrong with it before you can fix it. I would start by taking the screen off but be very careful. The glass is fused to the LCD, so if you damage the glass or LCD, you'll need to buy a whole new screen assembly. Follow the ifixit guides to take it apart.
por
Adicionar a sua resposta
Russell será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 36
Ao todo: 1,458
