Ir para o conteúdo principal
Lançado em junho de 2012, modelo A1278. Processador Intel com Turbo Boost, até 512 MB DDR5 de RAM vídeo
1624 Perguntas Visualizar todos
Question mark folder at start
My unit will give a “? in a folder” symbol at startup. Removed and connected hard drive externally and unit boots up and operates fine. Ordered and installed a new cable that connects hard drive to logic board. Same problem; “? in a folder symbol”. Ran hardware test on startup and it is OK. Need some help please.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Your systems PRAM setting is messed up! So your system doesn’t know which port your boot drive is located.
With your drive properly in place restart your system and Press the Option (⌥)  to gain access to the Startup Manager, select your internal drive and you should now be booting up under it. We still need to get this firmly set still. Go to your System Preferences > Startup Disk, unlock the setting select your drive and then hit the Restart button. That should fix things.
Reference: Mac startup key combinations
If it doesn’t then the replacement cable is bad or damaged.
Did you reformat the drive and install a fresh OS onto it? Many a time the data on your drive is not clean because of the bad cable. I would first make a full backup using TimeMachine then redo the drive and restore your stuff back.
Esta resposta foi útil?
Pontuação 1
2 comentários:
The drive works fine when connected externally but is not recognized when connected with internal SATA cable.
por
That points to a bad HD SATA cable! MacBook Pro 13" Unibody (Mid 2012) Hard Drive Cable
Your Hard Drive Cable Is A Ticking Time Bomb Besides the cable its self and adding the electricians tape, the way you handle the cable is also important as many people damage it just trying to put it in.
Find an old BIC pen to take the empty ink straw out as you'll want to use it to help you form the bends. The cable's arc can't exceed the radius of the straw where you need to bend it. Folding/creasing the cable damages it!
por
Adicionar a sua resposta
Terry Chapman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 47
