The side adjuster of the right earphone
The side adjuster of the right earphone is broken, it's the part that holds and supports the entire earphone without it I have to hold the headphones while listening to music.
Esta é uma boa pergunta?
Hey!
Taking a look into the manufacturer’s page on this product this part seems to be built from cheap plastics and not intended to be user-serviceable, in which case it is going to be rather hard to get the replacement part, also the screws used are not of a standard bit shape, that also makes the fix harder. If you have the bit perhaps opening and taking a closer look at the part and craftily repair it with some run of the mill epoxy resin, I would recommend against super glue as its solvent has a tendency to destroy plastics.
Cheers, Enzo
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 32
