Navegue neste tópico para encontrar o local apropriado para este comentário. Em seguida, clique em “Anexar comentário a esta postagem” para movê-lo.
2 comentários:
@rll58 ... what error are you getting? i serviced a triton unit last month. im sure there are similarities that will help with what your is or is not doing.
found the service manual i had for the triton model. its not the same, however if you go to the troubleshooting section of the manual, youll be able to see what some symptoms and solutions are that you can apply to this model you have.
por technical fellow Compartilhar
http://www.ersbiomedical.com/assets/imag...
good luck.
