Ir para o conteúdo principal
A1418 / EMC 3068 / iMac 18,1 / 2.3 GHz dual-core i5 processor. Released June 2017.
iMac won’t turn on after upgrading RAM and SSD
I purchased 2 8GB RAM modules and 1 TB SSD to upgrade my extremely slow base model 2017 iMac. I followed the instructions meticulously, took me about 4-5 hours from start to finish and now the thing won’t turn on at all!
Where do I even start trying to troubleshoot the problem? Everything appears to be reconnected properly. I’m ripping my hair out as I need my computer for both work and school!
Update (08/06/2020)
2 led lights
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
I took everything apart again to double check the RAM modules, noticed one appeared to be slightly damaged so I swapped it out with one of my old ones. Put everything back together and everything is working now.
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
Locate the onboard diagnostics along the left edge of the logic board near the fan
What are they telling you?
Pontuação 2
1 comentário:
2 lights come on. I can only upload a photo as an answer.
por
Adicionar a sua resposta
Larissa Starr será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 389
