How do you replace a solenoid switch?
Diagram of solenoid switch
Esta é uma boa pergunta?
I assume it's for the starter. It's either going to be part of the starter and if it's not follow the battery cable from the starter and it should lead you to the starter solenoid. It should be obvious how to change it but before you do anything disconnect the negative battery cable.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 355
